I have an XVID Movie 640 X 352 Pixels, Frame Rate = 23/Second, Data Rate = 211 kbps, Video Sample Size = 24 Bit, Video Compression = XVID
Now I am using TMPGenc - 2.5 - Version # 2.58.44.152 - Core Version - 1.90.140... to convert it to VCD so that I can view it on my DVD player.
I had to cut this movie slightly by 10 seconds... 30 minutes into the movie because of a viewing glitch. I have successfully encoded the first part up to the glitch but TmpgEnc will not accept the rest. Obviously it has to do with the sound file not matching up ??? ( I Assume)![]()
Can someone tell me what to use and how to use it..to correct this problem.![]()
Thanks![]()
MLOR
If you can still load the original movie into TMPGEnc, do it, and use the Source Range function to encode the rest of the movie. Finally, Merge the two parts into one movie and burn.
Hello.
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 13:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
