I just recieved Media Cleaner Pro 4 from a friend and i was wondering what you guys know about it.
Comments, suggestions, etc.
My goal is to compress clips so i can post them on my website.
I tried to compress an Mpeg 2 file because it said i couldn't do AVI and after trying many formats to export to i would recieve no video. Audio would be there but no video.
it is one of the worse programs ive seen -- even the current owner of media cleaner says this version (and 5) were the pits ..
it went through many owners - now discreet owns media cleaner .. the curent version is 6 (XL) , which is a LOT better (uses the main concept encoder now) ..
it will takes you days if not weeks i swear to accually encode ANYTHING w/ that version .. -
even cleaner XL (which lacks many of the features of 5) seems to have some issues
http://support.discreet.com/webboard/wbpx.dll/~cleaner/read?52115,59
http://support.discreet.com/webboard/wbpx.dll/~cleaner/guests -
What do you mean it will take days even weeks to encode? Do you mean figuring it out.
IT seems very basic to use but i just dont see any video.
P.S. I dont have the money ot buy another app, i got this one for free and thats what i have to use. -
well i mean it it is very slow ..
there are many freeware and inexpensive apps in tools section ..
but if its all you got -- then use it .. but you can not compress to wmv 9 or even 8 i think
Ms has a free compressor which is pretty good and makes stuff for the web
http://www.microsoft.com/windowsxp/moviemaker/downloads/moviemaker2.asp -
Ok, but the speed hasn't been a concern because the times that i have tried it has been quick. IM just not sure why i see no video.
what is your source and what is your planned output ?
the MS movie maker is fine for making videos for the web (you would want windows media most likly)
NewBlue Titler Pro and Vegas Pro 11 (425) questions
By videobread in forum EditingReplies: 9Last Post: 17th Dec 2011, 11:29 -
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 07:02 -
Some questions about QuickTime Pro
By VidHunter in forum MacReplies: 1Last Post: 8th Jan 2009, 13:04 -
Registry Cleaner for WinXP Pro...
By retroborg in forum ComputerReplies: 5Last Post: 17th Oct 2008, 11:53 -
A Few Questions About Dolby Pro Logic
By seven_deuce offsuit in forum AudioReplies: 17Last Post: 29th Apr 2008, 16:08
