  1. Right, hope someone can help. Am getting this error, won't bore you all with it yet, how can I get tmpgenc to open and convert an mpeg. I was sure I had it on my pc but obviously I haven't and for the life of me I cannot remember where to download it from.
    PLEASE HELP !!!!
    Russ
    If it's wet, drink it
    My DVD Collection
    Apr 2002
    The State of Frustration
    Go to the Tools section at left.
    Hello.
  3. Not mpeg 2 , mpeg one I want to open it and then reconvert
    My DVD Collection
  4. I don't get it, the file plays fine in wmp but no program will open it.
    My DVD Collection
    Apr 2002
    You want TMPGENc? Look in the Tools section at left to find out where to download it, right?
    Hello.
  6. If the error message you are getting has something to do with unsupported, then you need to get the correct codec(s). Go to the tools section on the left side of this page and look under codecs. Or you can use AVICodec (also available for download from the tools section) and see which codec you are missing.
  7. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    You can always open it in Virtualdub Mod, then frame serve to TMPenc. Look in the tools section for Vitualdub Mod.
