For certain source files of mine, I am unable to frameserve directly to TMPGEnc. If I do so, even though the video shows up fine in the TMPGEnc preview, the encoding process will almost always end in a "stream writing" or "stream reading" error (usually "stream writing").
However, if I take the exact same AVS file, open it in VirtualDub, and then frameserve from VirtualDub, it works!
I'm sure that using VirtualDub as a middleman between AviSynth and TMPGEnc is causing a speed hit, and I don't understand why it is necessary.
I first thought that my "stream writing" errors were linked to the 2-pass VBR option in TMPGEnc, but actually they seemed to be linked to a combination of source file and AviSynth. In other words, I see these errors only when using AviSynth to frameserve, and only for certain source files.
What versions of all three programs are you currently using?
Try adding this line to the end of your AVS script.
ConvertToRGB24()
TMPGenc only supports RGB input. For a YUV source you must convert to RGB first, unless you are frameserving through VFAPI, in which case it does the conversion to RGB. -
I'm using TMPGEnc 2.512.52.161, AviSynth 2.52, VirtualDub 1.5.3 (build 16250/release-P4)
When I try to frameserve directly to TMPGEnc, I have to put ConvertToRGB24() at the end of my AviSynth script, otherwise I just get a black screen in the TMPGEnc preview. So, yes, I have been doing the conversion and still getting "stream" errors when I try to encode with TMPGEnc. I shouldn't have to use Convert, though. I installed HuffyUV so I could use that as the YUY2 decoder...(check out http://www.avisynth.org/index.php?page=Convert)
They say you can get better speed and quality by using HuffyUV instead of ConvertToRGB24()....but I still get no video in TMPGEnc unless I use Convert. -
Just as an update, I have found that by increasing the priority of the directshow filter in TMPGEnc, I no longer get the stream writing errors.
I should also add that the stream writing errors were only "mostly" reproducible and not "completely" reproducible...every once in a while, I wouldn't get the error on a very short clip.
One reason I didn't want to have to frameserve from VirtualDub is that you can only set up one frameserved file at a time, and thus can only have one vdr in the TMPGEnc batch encode list.
Although raising the priority of the directshow filter looks like a solution, I thought the directshow filter was not very good and should be avoided. Will using the directshow filter affect the quality of my encodes?
720p 59.94 to 480p 23.976 in TMPGEnc w/o Using AVISynth
By CubDukat in forum Video ConversionReplies: 6Last Post: 19th Oct 2009, 09:51 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
How to frameserve this resizing algorithm to TMPGEnc?
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 22:19 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38 -
Frameserve from VirtualDubMod to TMPGEnc
By pchan in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 08:13
