  1. Member LisaB's Avatar
    If you look at the page in the AviSynth manual:
    http://www.avisynth.org/index.php?page=Convert
    It gives very interesting info on how to get faster, higher quality encodes by installing HuffyUV. I installed HuffyUV, but I still get a black screen for video when frameserving to TMPGEnc unless I put a ConvertToRGB24() at the end of my AviSynth scripts. Does anyone know what else I can try?
    I'm using the latest versions of both TMPGEnc Plus and AviSynth...are they compatible?
    Apr 2002
    The State of Frustration
    If you get an error message when opening like file unsupported or can not open or is not supported
    or you get an empty(black) video preview windowor the video look wierd in the video preview window like green or purple or pink
    Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and try open the video.
    The Newbie Guides.
    Hello.
