Hello, I need help. I am try to burn VCD image
file on my Harddrive and then use that image to burn
multiple CDs.
I follow the procedure to make image file ISO but when
I try to burn, it would not work tell me blank CD have
not enough space on it. I am using NERO Ahead, I do
not get it because I make image from VCD which was on
same size CD but when I try to burned back the image
to blank CD it keep on failing.
Please advise
The question is, what is the size of your image file, and what is the size of the CDR's you are using to burn that image to.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
The image file size is 788 MB and I am using 700MB/80Min CD. I burn image from VCD which was on same size CD but after making image of same VCD why I can fit back on CD
Thank you in advance -
That image size should burn perfectly on the 80min CDR, but only if you made the image correctly. If it's a VCD image, there shouldn't be a problem, if it's a Data Image, you will need a 90min/780mb CDR instead, and i'm not even sure if that will fit.
Best Regards,
Sefy Levy,
Use isobuster (free in tools section) to extract the avseq01.dat file from your iso image. Open the mpegav folder ,right click on the .dat file and
select extract but filter m2f2 frames . Save as filename.mpg in a folder you can find again. Finished close isobuster.
Open nero, close the wizard and select vcd template from the left hand window.
Select whether ntsc or pal and set burn speed. Click new and navigate on the right window to where you saved the .mpg file.
Drag the file to the bottom left window and nero will check if it's compliant.
If all is ok click the burn tab at the top and away you go.
If there's a problem with your .mpg dont let nero re-encode it for you, instead run it through tmpgenc (free)using the vcd template (ntsc or pal) to make it compliant.
Image Burn & Miscompare
By Bazza-61 in forum Authoring (Blu-ray)Replies: 16Last Post: 17th Jan 2011, 05:42 -
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 12:06 -
Image Burn SLIP
By wulf109 in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jan 2010, 16:18 -
Best way to burn a working DVD from an image
By kelman4 in forum MacReplies: 5Last Post: 2nd Apr 2008, 21:29 -
Erase BD-RE with Image Burn?
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 29th Feb 2008, 14:34
