Hi
i dl the trial version to TMPGEnc to see how it works before i purchase it. anyway i seemed to work fine on win xp but when i upgraded to win xp sp1 it kept coming up with an error and would crash. the error was with some memory address issue or somethign. i then formatted my pc and put win xp sp1 back on and now this prog comes up with the not responding error every time i have tried it. i want to cut and merge my dv movies.
i have ver 2.02.31.119 of tmpgenc. could it be that ver has an issue with win xp sp1
thanks for your help
poison
The best way to know, is to download a recent version instead of such an old one that you have, latest is 2.511 or 2.512 8)
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
i dl the latest version and it still does it. but i have found out what causes it to crash, i am trying to edit some movies that were captured from my dv camcorder through ulead videostudio. on every movie of this type it does it. they are mpeg movies. the play fine on the pc just want to cut some out if them. anyway tmpgenc works fine on another movie i tried. just not any that have been done with ulead.
the current version has tons of problems. On my AVISynth script that worked perfectly in the previous version, it doesn't encode the correct number of frames, screws up the timecode, and generally just causes all sorts of mess of troubles. I have heard that if you don't close all GOPs it can screw things up with this program, but at 18 hours an encode (high quality on a 2 hour clip), I am pretty much done with messing with this mess.
There goes $50 down the drain until the fix it. I wish I could download the previous version.
Closing GOP's can certainly help with editing, that's for sure!
Best Regards,
Sefy Levy,
so is the 511 version better than the 512, i can dl that version as well if it is better
cheers
poison -
Personaly i'm using the 2.512 version and I have not yet run into problems.
Best Regards,
Sefy Levy,
AVIdemux keeps crashing
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 13:32 -
x264 keeps crashing
By MR 3 in forum Video ConversionReplies: 6Last Post: 17th Jan 2010, 14:29 -
My Avidemux Is Crashing
By bigman70 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 11:54 -
MPV crashing
By SignedupGuest in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 15:38 -
Powerdvd keeps on crashing...
By uehara in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2008, 19:58
