i am trying to load d2v file to CCE created with DVD2AVI but CCE is msg me that the framrate is 20000!! how can it be? how can i change that?
my movie in DVD2AVI show inded 20.000fps why?
It sounds as if you might have missed a setting in dvd2avi. When you did your preview in dvd2avi did you remember to set the field operation to "None"?? 20.00fps is not valid and would only be reported if you have "forced film" activated under video/field operation.
More than likely you have a pal source which is actually 25.00fps. You will need to create a new d2v file using the correct settings in dvd2avi.
good luck
Guidoo
CCE does not accept d2v input. You have to frameserve one way or another.
You have several options. You can use VFAPI converter to create a fake avi file from your d2v file, which CCE will load. The best way to frameserve is through avisynth. This will increase your encoding speed by possibly up to 30%. I recommend getting FitCD to create your avisynth scripts, at least til you get the hang of it. Just load your d2v file and fill in the output settings you want and it will create a very well written AVS script for you. Then just load this in CCE and it should encode fine. -
Adam your right about needing to frameserve to CCE. Wizzy did not state he was frameserving. I gathered he was since CCE gave him the 20000 framerate message. He couldn't get that message if he weren't frameserving somehow.I don't wont think CCE will open a d2v file at all , hence couldn't give him the framerate error.
Guidoo
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
