Hi!
I've just bought a new DVD writer(HP 300n) and I've got a question relating to TMPGenc.
Before my dvd days I used to encode my divx files as SVCD Pal in TMPGenc and was quite content with the result.
If I encode them as DVD Pal instead will it make any difference qualitywise after I've burnt it and play it on my standalone DVD?
Could it be that not all standalone DVd players will acceot this kind of disc?
I'd be grateful for an answer.
Nille
I did notice my video was much better in DVDs than in SVCDs. I really like the extra memory it gives me as well. As for which players will play your discs, you can always check the DVD Player database at left.
Hello. -
Thanks for your answer.
When it comes to the setting in TMPGenc how high can you go when it c omes to "average video bitrate" and still make it playable on a standalone dvd player?
They mentioned that the average bitrate on an original DVD was somewhere between 4000-6000.
Nille
Would NTSC DivX play on PAL equipment?
By videoboy2008 in forum Newbie / General discussionsReplies: 4Last Post: 10th Apr 2008, 03:43 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 24th Jan 2008, 00:13 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 13:13 -
Converting PAL to DivX
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2007, 20:27 -
DVD TO DivX (PAL 720x576 16:9 Letterboxed)
By SamFisher in forum DVD RippingReplies: 16Last Post: 10th Jul 2007, 20:17
