I used to be able to choose either left or right channel w/ MS media player 6.4, but now that I installed 7, I don't know how to, can somebody show me how?
Use the balance control in your soundcard's mixer (or Windows volume control if you're using that).
Using the balance control would only shift both sound channel to be played on left/right side of your speaker, it doesn't just play one channel..
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 04:35 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47 -
What podcasts do you listen to?
By stryker in forum Off topicReplies: 3Last Post: 17th May 2007, 13:56
