how can i make my own outro? i want the last frame to fade to a blank screen or video like this one. thanks![]()
I use Video Studio 6. Using the Storyboard function, I load my video, then go to the pull down menu at the right. Select Image. I then use the little folder icon to call the browser to find my image, and Open it. Dragging my image to the box next to my video, and select how long you want it to last.
Now, select the Effect function, since you do not have a registered version, which gives you the Crossfade function, you can use the Dissolve effect instead. Once you select it, and drag it to spot between your video and your exit image, select how long you want the transition to last. Three seconds is usually good for me.
Go to Finish select what kind of file you want to save it as, then you are ready to burn.Hello.
Editing Question about Virtualdub
By gatewayedit in forum EditingReplies: 5Last Post: 14th Jul 2011, 17:26 -
VOB Editing question
By jeffboyrd in forum Newbie / General discussionsReplies: 4Last Post: 9th Oct 2010, 11:47 -
editing stage question
By ht0160 in forum EditingReplies: 3Last Post: 2nd Jun 2008, 12:04 -
editing question
By Noobmeister in forum Newbie / General discussionsReplies: 12Last Post: 1st May 2008, 19:19 -
???? Question About Film Editing
By shellelyn in forum AudioReplies: 4Last Post: 3rd Mar 2008, 18:50
