"Enable padding not to be lower than minimum bitrate"
Well, that is one of the options in the settings for 2-pass VBR in TMPGEnc. It suggests that if you don't check it, then the bitrate might fall below the minimum bitrate. Huh? Isn't this a contradiction? If the minimum bitrate isn't really a minimum bitrate, then what is it?
Sounds like it would be a suggestion. As in "Please do not let the rate fall below x". Then the padding choice tells it how hard to try. With no padding it tries to conform, but the rate may fall frequently. With padding the rate shouldn't fall, but things also happen.
I try to put my VBR min rate at 0 (zero). If there is a long freeze-frame period the rate can drop out completely if need be.
Some 'pros' may want to chime in here...
- Styro -
Not a "pro" here, but...
My Apex craps out and freezes unless the min is at 300 (padding enabled)."Art is making something out of nothing and selling it." - Frank Zappa -
Two barriers where players like "crap out" -- the 2.0 MB/S barrier on MPEG2, and the 500k barrier on any MPEG file. They fall within the ranges pretty closely usually. Go higher, buy more discs. Most players will have issues if you try to go too high or too low on bitrates. My Toshiba stalls on anything below about 500k and give problems below 900k.
I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
minimum configuration for 1080p
By xenotox in forum Media Center PC / MediaCentersReplies: 26Last Post: 30th Nov 2009, 15:31 -
Minimum PC Requirements to do HD Video Editing?
By dan1st in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2009, 18:29 -
Minimum Reqs For HDTV PC
By JBreits in forum Media Center PC / MediaCentersReplies: 13Last Post: 17th Oct 2007, 15:26
