OK, I've been using TMPGEnc for over a year now with no probs, but recently, I can't adjust the sorce range anymore? Like the first half of the movie is ok, but everytime, when I move the slider to somewhere in the second half of the movie, TMPGEnc closes. Any ideas why? This is really frustrating. Does anyone know any similar programs like TMPGEnc that does the same thing? Thanks.
Results 1 to 20 of 20
Yes, my incarnation of TMPGEnc crashes too, if I move the slider so select source range - just like VirtualDub does on occation. The cure is not to use the slider(s) - move around by entering time in the text fields instead.
/Mats -
Mine used to never crash when I moved the sliders, up until recently. I tried not using the sliders and just entering the numbers before, it will start encoding, but once it gets to a certain part in the second half, it will get an error or crash and stop. I can't encode the second half of my movies!
Try to mux the video.....after you merge back together try again hopefully this helps
Anyone else? Had this problem a long time and really want to get this working again
Or if anyone can suggest a similar program that can do the same job?
Have you tried as Mats suggested...
Instead of sliding ther bar,enter the time manually in the field box?
Have you uninstalled then reinstalled TMPGEnc ?
Do you have any progs running in the background?"Today is only yesterdays tomorrow" -
Are you using the latest version, or the year-old version?
Hello. -
What kind of file are you feeding in...XVID,DIVX ?
Are you using an extracted WAV as audio source?
What is you environmentals settings in TMPGEnc?
(top priority etc)"Today is only yesterdays tomorrow" -
I've tried 2.5 and 2.513Originally Posted by Tommyknocker
Originally Posted by wee haggis -
The VFAPI settings. Also, how much RAM do you have on board?
Hello. -
Name - File - Priority
AVI2(OpenDML) File Reader - - 0
BMP/PPM/TGA/JPG File Reader - - 0
CyberLink MPEG-2 Decoder - - 0
Microsoft MPEG-1 Decoder - - 0
Wave File Reader - - 0
DVD2AVI Project File Reader 1.77.3 - DVD2AVI.vfp - 0
TMPGEnc Project File Reader 2.513 - TMPGEnc.vpf - 0
DirectShow Multimedia File Reader - - -1
AVI VFW compatibility reader - - -2
1GB of RAM -
Try moving the Direct Show to 2 and the AVI VFW to 0, and see what happens.
Hello. -
same thing
Grrr, can anyone just recommend another program that does the same thing as TMPGEnc?
I heard I should try using DVD2AVI 1.76, does anyone have this older version or know where I can get it?
Do not know about DVD2AVI, but I do know Video Studio can convert to AVI, SVCD, VCD, and DVD files.
Hello.
adjust angles
By ecos in forum EditingReplies: 2Last Post: 31st Jan 2012, 18:00 -
Index Out of Range
By bessen69 in forum DVD RippingReplies: 6Last Post: 25th May 2010, 09:34 -
How do I adjust the sound
By mmkk in forum Video ConversionReplies: 2Last Post: 28th Dec 2009, 14:52 -
Temperature Range
By Seeker47 in forum ComputerReplies: 12Last Post: 6th May 2009, 17:15 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 20:19
