I recently downloaded the 15day trail version of Dr. DivX 1.0 to convert mpg files to avi file for upload. (www.DivX.com)
Good points:
1. The program is very easy to use and can encode many file types.
2. Gives enough settng/otions to customize your conversion.
3. All-in-one converter, seems like the easest way to do it.
Bad points:
1. Installs GAIN adware. My Norton Internet security can block it.
2. Shows a DivX logo in the bottom right for the first few seconds. Im not sure if this happens only for the trail version.
3. Not Free, $49.
4. Quality is questionable, I haven't experimented wirth the settings yet.
Can anybody else comment on there opinion of Dr. DiVx?
The Divx logo for the first few seconds isn't just in the trial. I paid the $49 and still get it in my encodes. On the good side, it does a two pass encode in about half the time it takes VirtualDub to do it...
I have 2 pass encoded a few rendered DVD mpg files of RC trucks racing to the High def DivX configuration at 1000KBs. The trucks fast movement generates some pixel-smearing after encoded.[/img]
DivX H264 Encoder
By Anakin in forum Video ConversionReplies: 1Last Post: 21st Jan 2012, 14:04 -
Best avi/divx to dvd encoder
By deanofire in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2009, 15:16 -
Help Finding all in one dvd to divx ripper/encoder
By elloco07 in forum DVD RippingReplies: 5Last Post: 13th Jul 2009, 09:44 -
First release of DivX h.264 encoder
By kosmonautbruce in forum DVD RippingReplies: 1Last Post: 25th Aug 2008, 14:15 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 01:35
