Results 1 to 9 of 9
  1. DVDSHRINK
    brief discription of these 2 required
    re-author
    re-encode
    what is the difference
  2. Member tim_k's Avatar
    Feb 2003
    Re-author- Remove unwanted features of the movie.
    Re-encode- Update links to correct for removed features.
  3. Re-author- Remove unwanted features of the movie.
    So do we re-author to remove the stuff we dont want
    THEN re-encode??
  4. re-author is for making movie only menu wont work in this mode
  5. so the re-encode has to be used the re-author is optional
  6. I always re-encode, and drop all special features to minimum quality. Ditch any foreign audio tracks and you can usually still get a very good quality main movie.
  7. Re-encoding is NOT always necessary.
    The aim is to get a DVD9 movie on a DVD5 disc. If you want to include all the menus, extras, additional audio tracks, etc...then there's no getting around re-encoding.
    If you're just interested in the main movie, without menus, etc...you MIGHT be fortunate enough to fit the main movie on the disc WITHOUT re-encoding (as long as the total size of the files is less than 4,489 MB), this is where you would use the 'RE-AUTHOR' option.
    If after stripping the DVD9 from all additional crap, the file of the main movie is still too big to fit on a DVD5, you can SPLIT the movie (without re-encoding) to fit on 2 DVD5's (while keeping the original quality), or RE-ENCODE (and losing some quality).
    So.....SIZE DOES MATTER ! :P
    Hope this helps.
    Flipper.
  8. True. Personally I like to keep the menus though, and am willing to sacrifice a small amount of pic quality to do this. As I said all extras are already compressed as much as possible so I usually get away with a level 3 at worst.
    Remember though that my backups are the ones that get used, the originals are kept safe. Not all, just the ones we tend to watch while wasted. I still keep the originals safe so if anything happens to my copies I have a perfect source to get them back. Since these are more stoner films, we can never tell at a small loss in quality cos we're wasted! If your backing up to actually keep as the backup, then try to keep full quality.
