  1. I recently created a slide show in DVD-R format with ULead Video Studio 6.
    The slide show worked very well.
    However as it was only about 600mb I decided to burn a copy onto a CD instead of using the more expensive DVD-R.
    This also worked well in MOST DVD players however it does not produce any audio in some players (mainly Philips)
    Does anyone know why and if there is a workaround?
    Pete
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    How did you get a CD_R with authored DVD-Volume to play in a settop player?..
    What brand was it?..most unusual....
    MOST? I only know of 4 or so players that play DVD on CD in my experience!
    I assume the audio was PCM and the PHILLIP won't play PCM is my guess
  3. My set top player is an Hyundai DVD-360A
    And it plays allmost anything !
    But I have a mate who has a Phillips (not sure what model) and that is a very fussy player !
    Pete
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    What I'm aying is you have the FUSSY player!
    IN a GOOD WAY!...FUSSY enough to play a format
    UNSUPPORTED by 95% of DVD players
    DOESN'T matter whetther your project is a DVD VIDEO or DVD AUDIO-
    IF IT ON A CD SURFACE..and If its a DVD FORMAT with .TS and .VOB's
    It will not play in 95% of the players out there
    You friends PHILLIPS is the norm!
    (ps I wish I'd gotten a HYUNDAI!)
