i have an avi 23.97 that i converted in tmpge to an mpeg this file plays fine on my pc( i used kvcd template for ntsc 23.97)
when i use dvdlab to author the resultant file plays juttery
i also have another avi that i didnt 3-2 pulldown and dvdlab pulls it down and messes it up
help plz im lost
Is this a KVCD in mpeg1 format...If it is when you put it through tempgenc you should have converted to 29.97. Mpeg1 should be 29.97 to be DVD compliat.
Try using TMPG's own DVD template. DVD is mpeg2 format and must either be encoded at 29.97 fps, or 23.97 fps with a 3:2 pulldown applied so that the film plays back at 29.97 fps. I notice that you live in Leeds. Wouldn't you be better off using a PAL template?
the source is 23.97 would i be able to convert to a pal dvd with good enough quality output
also the clip is near 3 hours long(cameraman got carried away lol)
and i want it all on a dvd+r -
Try using this guide;https://www.videohelp.com/forum/userguides/78178.php and see if that helps. The quality depends on your bit rate. The higher the bitrate, the better the quality. It also means a larger file size of course.
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 18:04 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 14:09 -
DVDlab menu question
By rizay in forum Authoring (DVD)Replies: 3Last Post: 12th Dec 2007, 08:54 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 04:55 -
problem with dvdlab pro2
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2007, 06:00
