  1. Here be the problem. I have bin and cue files that I burned svcd's from. I ripped and converted them to files to burn on DVD. The files are in PAL format however and I wanted to convert to NTSC. I used the 'STANDARDS CONVERSION' page and followed the instructions. Everything seems to work fine. I authored a DVD with IfoEdit. Before I burned, I opened and tested the file with PowerDVD. Video was fine but the audio was way off. Any suggestions on how to get them back in sync? Any help would be greatly appreciated. I am running out of hair to pull out!
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Sounds like you didn't convert the audio from PAL to NTSC. You need to extract it from your source file, and use something like BeSweet (get BeSweet and the BeSweet GUI from the TOOLS section), to convert it from PAL to FILM. It has a drop down selection for just such a conversion.
    Impossible to see the future is. The Dark Side clouds everything...
