i am fairly new to all of this but i am wondering if anybody knows of a stand alone dvd player that with play raw mpeg and/or raw avi's? or if there is any thing out there that can be made to read them?
any help would be greatly appriciatted.
I believe there are several Apex players that play raw mpeg files, like the 1200 for instance. There is a Kiss DVD player for Divx-Avi's.Originally Posted by bbapties77"Art is making something out of nothing and selling it." - Frank Zappa
My APEX 1000 and the APEX 1110w I bought my father will both play
raw MPEG files. However, they must be a width/height that all conventional DVD players recognize.
I tried to play a 640x480 MPEG file, and the display got screwy and twitchy.
As for AVI's, I have no idea.What's "taters", precious? -
i appreiciatte it. now that actually brings up another question. i was actually incorrevt in my wording.
when i said raw mpeg i actually meant a ***.mpg (video file) or is it fairly easy to convert to a ***.mpeg
maybe its because i am just starting to figure out how this stuff works but i have tried a couple conversion programs to convert a mpg file to some type of vcd but have not suceeded.
any suggestions on programs for dummies would help alot
thanks again -
When I first started, I used Nero Burning Rom. It's very, very easy. The quality is OK - not as good as using a separate program (like TMPGEnc, or CCE) to encode to .mpg, but watchable. Nero has a wizard that you can just drag and drop .avi files into, and it will convert them, then burn them. Even if you have an MPEG file that is not VCD complaint, it will take care of it for you. It takes about 5 minutes to set up, then in a few hours (depending on how long your video is) you've got a VCD. I used to set it up right before going to bed, then in the morning it'd be done.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
How to play cdg files on dvd player?
By LivD in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2012, 13:23 -
How to play raw DV files?
By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2011, 08:00 -
How Do I Play Raw DV Stream Files on a TV?
By NY2LA in forum Software PlayingReplies: 97Last Post: 30th Jul 2011, 00:21 -
Do Any Blue Ray Players Play raw m2ts files?
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Nov 2010, 22:41 -
How to create .mp4 file by using raw .h264 and .aac files for JW Player
By hakkinen in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 21:49
