My system is as follows:
1) Celeron 1.7 @ 1.9
2) MSI MS-6524 motherboard with AGP 4X
3) 512 MB PC-133 SDRAM
4) Western Digital 80 GB, 7200 RPM hard disk
I'm planning to upgrade to Shuttle AV49N motherboard and two sticks of Kingmax 256 MB PC3200.
The motherboard supports:
400 MHZ and 533 MHZ FSB Processors
8X AGP
Hyperthreading Technology
DDR 400 MHZ
Will the encoding time will be improved after upgrading? What do I need to put Hyperthreading Technology to work and how does it work?
If you're gpoing to upgrade and go the Hyper-Threading way, you should investigate the new motherboards based on Intel's Springdale chipset which supports 800MHz FSB. Anyway, if you want HT, you only current options are the 3.06GHz P4 with 533MHz FSB and the 3.00GHz P4 with 800MHz FSB. The costs might not be very different in the end. Check out
www.tomshardware.com for more info on Springdale. -
If you are ONLY planning on upgrading your motherboard and memory, but not your processor, your perfomance will not be that noticable at all. I'd suggest building a whole new computer with at least a P4 processor and more memory.
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 11:38 -
Playing dvds recorded fron tapes on a Sansui dvd recorder, on a LG RH399H
By Eric2011 in forum Video ConversionReplies: 11Last Post: 6th Jul 2011, 05:56 -
Is PC2-3200 the same as PC3200 RAM?
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 7th Feb 2010, 10:33 -
DVB-S TT-budget s2-3200
By mb508 in forum DVB / IPTVReplies: 2Last Post: 13th Jun 2008, 06:10 -
DVD Shrink Pause Issue - Problem Resolved with v2.5.3200
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Sep 2007, 03:58
