  1. To date, I've only used IC for 2 movies and had the settings set at automatic to determine the encode level/output size. Both come up about 4G. Thus I thought that looking into the registery hack.
    For Terminator 2, I used DVDshrink to cut off the intro and credits and to strip out unnecessary audio. I then used IC to set manually set the target ouput level size. Version of IC is not the latest release. This is where it got interesting.
    Target set Actual Size
    4.46 4.82
    4.35 4.77
    4.20 4.73
    Automatic 4.75
    4.00 4.64
    3.50 4.52
    3.10 4.38 (IC says to big to burn)
    3.08 4.37 (Monitor preview looks great)
    I thought that normally the actual size was SMALLER than the target set size. I'm not complaining but what is going on here? Did using DVDshrink first to edit the movie drastically effect the estimation capabilities?
    Just looking for some analysis/thoughts here.
  2. I have made 4 copy with the new patch 7.1.1
    I set the size to 4.38 (or 4.39) and always get near 4.34 output size.. the new patch help a lot with this issue
    Mar 2003
    I have the new patch as well, but Instant Copy will only allow 4.32GB MAX. I don't understand why either.
    Feb 2003
    Chicagoland
    orbital517,
    After you have the size set to what you want, just press F5 and the Ok Button will become usable again.
    "We are all flowers growing in God's garden, that is why he spreads the sh*t around."
    David Byrne
    Mar 2003
    Originally Posted by wot_fan
    orbital517,
    So I can set it to 4.38GB and then hit F5 to allow the processing to go through? Does it run into problems while burning or anything like that?
  6. F5 will let you slide the the size limit beyond green and into the red.
    Feb 2003
    Chicagoland
    Yes that is correct. In my experience, IC7's (w/latest update) output is slightly undersized. I therefore set the output size to be slightly more than can fit on a disk. So far this has resulted in almost completely filled DVDs
    Using this method, I highly recommend that you send the output to the hard drive. You can than verify the size and quality before you burn.
    David Byrne
    Mar 2003
    I really appreciate all your help wot_fan
    It worked like a charm.
