It stretches it vertically to fit 4:3 ratio and does not keep 16:9 ratio?
Any suggestions for other programs if this is not fixable? Only basic programs though. DVD Movie factory does not seem to work for me.......it increases the file sizes even though it is compiant.
All I've got in this world is my balls and my word.....
and I don't break them for no one! -
Read the manual. In it it says that "only 4:3 aspect ratios are supported". However, there are work arounds to getting a 16:9 video authored, just search the forum. Been discussed many, many, many times.
Actually did search forum.
I just did another search and found one thread about it but I was lucky because it was a bit off topic.
My must have been discussed a long time ago because I can't very much.All I've got in this world is my balls and my word.....
Hello
I let SpruceUP write a VIDEO TITLE SET which means it creates a VIDEO_TS folder on my HDD with all the DVD files in that folder.
Then I use IFOEdit to edit all of the IFO files to read 16x9 instead of 4:3
Actually I keep the menu(s) at 4:3 but change the movie itself to 16x9
I've only had to do it a couple of times but it seemed to work and I was able to do it (using IFOEdit) without ever reading a guide. In other words it is not hard to do.
When I'm done I create an image file using ImgTools (classic version) then burn with DVD Decrypter.
Thank-You
That is the way I read and was going to do it.All I've got in this world is my balls and my word.....
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 10:00 -
What is the magic formula for getting YouTube to accept a video?
By Asterra in forum Video ConversionReplies: 15Last Post: 5th May 2011, 01:39 -
Freemake Converter Doesn't Accept swf Video
By rckowal in forum Video Streaming DownloadingReplies: 4Last Post: 25th Dec 2010, 17:10 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 16:46 -
Need A Software Video Player that can accept a command line argument
By SCDVD in forum Software PlayingReplies: 7Last Post: 14th Aug 2007, 13:38
