I am trying to convert my home DV into DVDs. I am wondering what is the best app to use? There are hundreds of apps out there. I am looking for some motion menu authoring like the one in Matrix!
What are my options? Don't want to spend more than $1000. It has to be easy to use withount having to read 600 pages of materials to learn it!
Thanks.
Results 1 to 16 of 16
"Seek you will find it"
It's TMPGEnc DVD Author. It's good and easy to me. It supports AC3 and menu.
Try DVD Lab. It's only $79 and does everything the overbloated and overpriced packages do and then some. Got it and I like it. Check out the link on the Latest News.
Correct if I am wrong, DVDLab does not support motion menus?
It can not encode wave to AC3 sound?"Seek you will find it" -
No DVD authoring app will produce complex motion menus automatically. For this you have to produce yoyur own animations, (in mpeg), overlay subpictures etc, etc. Its a fairly complex process.Originally Posted by icemanatvcd
DVDLab will allow you to use externally produced motion menus, as will several other authoring packages.
If you can be satisfied with simple motion thumbnails of your chapter points, then try Dazzle DVD complete (a bit buggy tho) or Ulead DVD Workshop 1.3 (also a bit unstable, at least for me). I am sure there are others. -
Thanks for that bugster. You seem to know your stuff. I will give Ulead a try.
Does anybody else knows other apps which will do simple motion thumbnails of your chapter points?
Thank you."Seek you will find it" -
Ulead DVD Movie Factory or Sonic ReelDVD will create motion menus; these packages are in the entry level to semi-pro price range
DVD Lab will do motion menus... it just won't do it all for you, you have to author the motion menu clips in a video-editing app and import them as assets.
check here for more info: http://www.mediachance.com/dvdlab/Help/index.htm- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
The best thing is to download and try out a few of these apps -- only you will know how they suit you.
Ulead has demos of all of their stuff, although it's usually crippled somewhat (and usually isn't the latest :<() DVDLab has a fully functioning demo and I would *strongly* advise you to at least download it and try it out (it will work for 30 days -- if you can't create anything you like in that period it isn't the program for you)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Oh, should add that "best" is a subjective term in this context. DVDLab is probably the "best bang for the buck" -- at $79 it's at least as powerful as Ulead's $500 program. Adobe's Encore (coming soon to a theater near you) will probably end up being the "best professional DVD authoring solution for the PC that's currently being sold" and at $600 it ought to be. The TEMPGenc author solution looks to be a cheap and easy to use app (I'm not sure if it does motion menus, though).
Thank you guys. I have tried DVDReel, preview window sucks on this app.
I hve to wait for Adobe Encore.
I am trying DVDLab, it seems great so far. I hve will follow the guide on doing a motion menu, see how it turns out. At that price it seems a bargain and easy to use."Seek you will find it" -
I wouldnt suggest anything other than DVDLab, or Sonic DVD Producer 3.5 for your purpose. I think Sonic DVD Producer is more than 1000 dollars though, not sure. Otherwise stick with DVDLab. Definitely not the ulead stuff.
Not sure but maybe DVD-Architect? -
As has been stated above, if you want motion menus like the matrix, you are going to have to have a fairly hefty video editing application like Adobe Premier with After Effects, or something similar. No program can make menus like that on their own, the reason being that all these menus are is a movie playing in the background of the menu. So what you need is to create this movie, loop it in the menu, and then place buttons on top of it.
Not all authoring apps can do this, and not many you could probably afford. DVD-Lab is a good option that is affordable, and it does the same stuff that others closer to $500 and even more can do. I am impressed with it so far. -
Ulead DVD WORKSHOP supports motion menus:
http://www.ulead.com/dws/runme.htm
Here is a step-by-step tutorial that explains how to do animated backgrounds:
http://www.ulead.com/learning/dws/dws_01_1.htm
Here is a step-by-step tutorial that explains how to do animated buttons:
http://www.ulead.com/learning/dws/dws_02_1.htm
Jerry Jones
http://www.jonesgroup.net -
Actually you can make those Matrix like motion chapter selection menus very easily with some freeware tools:
TSCV
http://www.doom9.org
ChapterAnim V0.89
http://membres.lycos.fr/luckyrip/en/index2.htm
AVISynth (IF you get really creative)
The key being 'fairly easy.' A lot of people have trouble using TSCV (it appears to be unsupported and dead at this point). CHaperAnim is written by a french author so all the defaults are in PAL (720x576). The documentation is 'lite' but it's fairly easy to figure out. I just used M$ paint and photoshop to make new images (at NTSC resolutions).
TSCV is a much better program for making these chaper based motion menus IMHO. As you can more easily move everything around AND add text prior to encoding the MPEG.
There is a guide 'somehwere' for making motion menus with AVISynth. Bottom line is it can be done but is a pain in the a&&... -
He asked about motion menus.Originally Posted by gotodvdr
Right now, TMPGEnc DVD Author cannot even handle audio background in menus, let alone motion menus.
I have tested many packages in the last three weeks, DVD Lab seems to be the best by far. (Unless you can afford Scenarist
Best bet is to grab some of the demos and play around with a DVD-RW, see which one you like. Sonic have a couple, Ulead have some.... but DVD-Lab is my choice. http://www.mediachance.com/dvdlab/index.html
Hope this helps.--
Will
Need one app to trim, crop, menu, chapter and author to DVD... in batch!
By bhershey in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2011, 13:06 -
Best DVD compressing app?
By headless chicken in forum MacReplies: 1Last Post: 21st May 2010, 00:36 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
App like DVD Shrink?
By Hondamaker in forum DVD RippingReplies: 4Last Post: 6th Dec 2008, 03:59 -
Which is best app for DVD to DivX or AVI....?
By snadge in forum Newbie / General discussionsReplies: 26Last Post: 1st Feb 2008, 12:14
