I've been learning to author dvd's for a couple of days. Today I spent a few hours using Move Factory to take 5 mpeg1's and convert/burn them to standardized DVD format. The problem is that the audio is desynching- sometimes badly- not long into the movies. What's causing it? What can I do to fix this? Thanks.
Don't use MovieFactory or any Ulead product. I've found they all cause sync problems.
I have had nothing but problems with audio/video sync problems using Ulead DVD M2. The only authoring software that does not produce this problem (so far for me) is TMPGEnc DVD Author. It has a free 30-day trial period.
Check http://www.pegasys-inc.com/
Audio desync after a while on Mpeg TS
By Liss0 in forum Video ConversionReplies: 0Last Post: 14th Jul 2011, 07:05 -
Audio desync problems when capturing with Fraps
By ecjezl in forum Capturing and VCRReplies: 4Last Post: 29th Jun 2011, 23:48 -
BIggg audio desync help!
By iamtrojan3 in forum AudioReplies: 1Last Post: 17th Jul 2009, 03:05 -
PSPEnc converions having audio desync issues
By godfist314 in forum Portable VideoReplies: 2Last Post: 13th Sep 2008, 10:45 -
Audio desync in Autogk
By godfist314 in forum DVD RippingReplies: 3Last Post: 5th Sep 2008, 11:22
