I have an XVID Movie 640 X 352 Pixels, Frame Rate = 23/Second, Data Rate = 211 kbps, Video Sample Size = 24 Bit, Video Compression = XVID
Now I am using TMPGenc - 2.5 - Version # 2.58.44.152 - Core Version - 1.90.140... to convert it to VCD so that I can view it on my DVD player. When I drop the Audio in....in Project Wizard 2/5 it tells me that the file is unsupported. When I play the movie thru Windows Media Player #9 it plays perfectly(with sound). Do I have to produce a seperate sound file for TMPGEnc encoding to VCD and If so....HOW?
Can someone please share some lightas I am totally baffled. Please HELP.
Thanks MLOR![]()
open the video in goldwave and save the audio as a wav file then use this in tmpgenc
if it's ac3, install Odio Dekoda
http://www.moonlight.co.il/download/?dl=odiodekoda -
the audio is in a format that tmpgenc wont recognize. in vdub open the xvid file and go to audio...full processing mode then to audio...compression and select uncompressed PCM and click ok. then click file...save wav and save it where ever. then in tmpgenc use that as the audio source.
The above method works fine as long as the audio is not AC3 or VBR-MP3, if it's one of those then use Goldwave instead.Originally Posted by xsbs52x
Also, you may need an audio codec. Check the file using Gspot from the Tools section."Art is making something out of nothing and selling it." - Frank Zappa
Save Xvid from Sony Vegas Movie Studio
By Cazz in forum EditingReplies: 12Last Post: 29th Jun 2010, 12:50 -
how to convert ps3 movie to xvid/avi?
By volam1 in forum Video ConversionReplies: 2Last Post: 24th Feb 2010, 15:13 -
Cannot Figure Out How to Convert .ISO Movie to XVID with FairUse Wizard
By cplevel42 in forum Video ConversionReplies: 14Last Post: 28th Sep 2009, 03:21 -
Running counter in XVID movie?
By drwho in forum EditingReplies: 3Last Post: 12th Oct 2008, 04:21 -
Problems with XViD
By trolldown in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 17:32
