Im trying to convert from Xvid to VCD, and i use TMPGEnc and VirtualDub.
First of, i open VD and open file, then i click on Video->Filter->Add->Resize, then i go back and click on Textsub, and i open the sub.
After that i go and click on; File->Start frame server,
Then i Open TMPGEnc, and i click on "Browse"
and i locate the .vdr file. And then PoFF:
File "F:\Filmer\Tears.Of.The.Sun.DVDRip.XVID-ViTE\CD1\vite-tots1.vdr" can not open, or unsupported.
WTF... I have converterad like 10-15 movies like this!! With subs, and i have never seen this...
Someone plzz help me!!!![]()
Seems to me that you have problems with the frameserving part of Vdub to Tmpgenc. That's not unusual, read the posts of this forum, more people have problems with this, one day it works, the next day it will not.
The solution: use a program that is intended to be used as a frameserver and has the same filtercapabilities as Vdub: avisynth.
Regards, Kees Janssen. -
try to reinstall the handler in virtualdub.
run "auxsetup" in virtualdub's folder, and choose "install handler".
i think this will work.HELL AINT A BAD PLACE TO BE
Wtf ? Camcorder freezes !!! Please help !!
By prattacking in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th May 2010, 22:42 -
WTF is with Ebay?!?!
By Noahtuck in forum Off topicReplies: 7Last Post: 29th Dec 2009, 19:33 -
filmindex.xml....WTF?
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 8Last Post: 6th Jun 2009, 07:01 -
From the WTF? Files
By Soopafresh in forum Off topicReplies: 7Last Post: 19th Apr 2009, 16:46 -
wtf is it?
By zoobie in forum Off topicReplies: 10Last Post: 25th Dec 2008, 17:03
