I've got an asus tv tuner card and am using the powervcr software that came with it, but everytime I run the program as a tv tuner the sound will cut out after a few seconds up to a minute. I can go back in and change the format (mpeg 1 vs mpeg 2 vs whatever) and the sound will come back on for the few seconds to a minute, but then will cut out again. The composite in works just fine - I recorded several minutes off of my camcorder with no audio problems. I also downloaded Windvr 3.0 and that program works fine (I just dont want to have to pay $70 for a new program when powervcr should be working). I have plenty of processing power (p4 2.4g with 512mb ram) and I have downloaded the most current asus drivers, and have tried re-installing powervcr, so I am at a total loss.
Any Ideas?? -- Cyberlink support wasnt much help
Thanks in advance
ive got a similar problem, i can caputre sound, but it keeps going normal volume-quiet-normal-quiet at 1 sec intervals, lets hope someone can help out.
Not sure if this will help or not, but I was having a similar problem (diff hardware - ati tv wonder, but also using powervcr). The sound would cut off after 30 sec to a minute while watching tv. This was after working fine for several months, seemingly out of the blue it started acting up.
Turned out to be a conflict between Norton Antivirus 2002 and Windows Messenger (don't ask me why this affected my tv card). Anyway, I turned off the IM protection in NAV and everything is fine.
I usually disable NAV to capture anyway, but not to just watch tv. -
thanks for your wonderfull help with the damn norton antivirus stuff
Now I can watch tv without hitting the mute button 2 times every min. when the sould would just cut out.
I have a kworld mpeg tv station BT-878RF-Pro I got from compgeeks.com
for 44.00 with shipping. I am using the tv program that came with the card for now and I tryied to use windvr and the sound would cut out on that prog. also. I was going to put a different sound card in if I could not get it to work soon.
Thanks againg for your help.
no more hitting the dumb mute button on my remote.
Audio cuts in and out
By the0ryyy in forum EditingReplies: 1Last Post: 15th Feb 2011, 17:41 -
Power cuts killing PC
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 11th Feb 2010, 08:55 -
MeGUI Cuts...
By MegaTonTerror in forum Video ConversionReplies: 4Last Post: 31st Jul 2009, 18:17 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 05:30 -
Audio Cuts out With GotSent on 5.1
By Calippo in forum Video ConversionReplies: 6Last Post: 4th Feb 2008, 20:29
