ssup all experts, please help with converting avi and mpeg files to rmvb format.
I have some rmvb files and found it quite usefull as of the small size. I can have like 400 mins of tv shows or movie in one CD and the quality are quite watchable.
I tried the Helix producer plus 9, but couldn't choose the VBR convertion from the option menu. it states the Multi-audience SureStreame is not supported for VBR.
anyone knows using Helix producer? or anyone knows any other program can convert to RMVB? some guide of those??
thanks in advance ~~
Click the audiences button
Select the profiles on the right and click on trash can to remove them from list
Then select whichever vbr profile you want
edit:
With HQ videos this format seems to give significantly higher compression than DivX for same quality.
e.g. Normally I encode widescreen videos from HQ sources at 600 kbps(video only) at 480 width and 4:3 videos at 400 width, with two pass DivX, when I post clips on the net. I seem to get same quality with 350 kbps including audio with rmvb format provided the original video is HQ.
Surprisingly it is as bad as before with non-HQ videos!!
Can Real Media files (.rm, .rmvb) be demuxed?
By Huh...What? in forum Video ConversionReplies: 5Last Post: 4th Mar 2010, 10:06 -
Question about 'Super' converting RMVB -> iPhone (MP4)
By blackhole001 in forum Video ConversionReplies: 8Last Post: 4th Jan 2010, 00:46 -
pls. help: converting .rmvb files using ffmpegX
By Dolly in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2009, 14:32 -
problems converting rmvb files
By Kavelian in forum ffmpegX general discussionReplies: 13Last Post: 15th Jun 2008, 11:58 -
Converting .rmvb files problems
By Gilberts in forum ffmpegX general discussionReplies: 7Last Post: 14th Nov 2007, 17:17
