I was hoping someone could help.Ive got a ati tv card and 533 amd and vodoo 3 graphics.I'm using virtual dub to capture video.When ever I capture any video I get a hissing almost like electrical noise in the background of the sound.Does anyone know the cause or a fix for the problem.If not does anyone know how to take the noise out.
thanks for the help![]()
This might help if you haven't already one it:
Disable all other audio sources in your computer except
from Line In. To do this go to Control Panel -> Sounds
and Audio settings. Open the Advanced Volume Controller.
Choose from the menu Options -> Properties and click
for Recording. If there or any other source then Line In,
deselect them.
If that didn't help try this: In VirtualDub, choose Audio and click for Full Streaming (or which ever corresponds to that). Open the settings for audio compression and choose at least 44100 Hz and 96 kbps.
Hope I've helped.
/Platin -
Depending on your sound card, you may require a driver update or system patch.
Is the background noise audible through normal TV viewing using the supplied software or is it present only during capturing?
I experienced a similar problem with a VIA 686 chipset which is covered in this thread.
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=56987&forum=2 -
Ive got onboard sound that I think Is the root of the problem.Ive got a m599lmr super socket 7 pc100board or at least I think that is what the boards called.lol
I think I've figured a way to take the high pitched buzzing out of the files with soundforge by smoothing the sound.I've still got to play with it to get it perfect,but have managed to take the annoying sound out.thanks for the help.
background noise in dvd (from .mov)
By nunsepofa in forum ffmpegX general discussionReplies: 6Last Post: 4th Mar 2012, 20:14 -
Dvd with background noise
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 09:58 -
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 09:24 -
Background Static Noise..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 00:28 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 21:27
