I have been having problems ever since I upgraded to XP. Now I can't use my tmpgenc to encode anything. I've read all the forums and done everthing I could like changing priority and everything. My next step is to uninstall and reinstall the program. I can't seem to get the whole thing uninstalled. I get an error message saying make sure disk is not full or write-rrotected and that the file is not currently in use. What the hek? I can't see any place were it would be running
Please help
I will not be able to check back until Sat. or Sun
Thank you for your help and understanding
Chodaro!![]()
Hello,
There may be a problem with a background process that means XP thinks that tmpgenc is still running. Try restarting your machine in XP's "safe mode" (by pressing the F8 key when the machine reboots until you see the XP start menu, and selecting safe mode from there), and logging on as Administrator.
Once logged on, try uninstalling the program again - it SHOULD work! Once uninstalled, reboot and log on as normal
Cheers,
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
Thank you Bolta I re-started my computer, tried to push F8 and nothing happened. I am the administrator. But, It seemed to work. Mabey I just needed to reboot. Thank you again
Chodaro
ok now I have another problem. I open tmpgenc and it is letting me put my avi and movie file in but when I go into settings then source it is saying there is no video source. Don't have a clue
Chodaro -
This discussion raises a question that I have had about uninstalling TMPGEnc.
I am running WinXP Home and no version of TMPGEnc (I have been upgrading regularly) has ever shown up on the Win XP install/remove list. I have been just installing the new version so that my purchase code transfers and then deleting the old version.
No problems have ever surfaced doing this but I have been curious as to why it can't be uninstalled in the normal way. -
Chodaro,
From what source is your AVI file? (ie downloaded, captured, ripped from dvd), and how is it encoded (ie a DivX file?). One trick that may work is to open the AVI file using VirtualDub and then frameserving it to TmpgEnc.
Another is to check the priority of the DirectShow file reader in TmpgEnc (Option / Environmental Setting / VFAPI plugin) and bump it up to the top of the list.
The success (or otherwise) of these suggestions WILL depend a lot on what sort of AVI file you have, so a little more information would be really useful.
Cheers,
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 08:31 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 16:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 15:59 -
How to uninstall a DVD burner
By DVinci in forum DVD & Blu-ray WritersReplies: 2Last Post: 25th Dec 2007, 23:34 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
