I've converted 3 AVI files to MP3 today with no problems by using TMPGEnc. I have three other AVI files where the resulting mp3 file has perfect video but no audio. Is there a setting somewhere in TMPGEnc that I'm overlooking? I'm using TMPGEnc to extract the audio from the AVI instead of a separate WAV file. I did use VDUB to extract the audio file separately but using the WAV file produces an MP3 file where the sound is out of synch. Anyone know a way to get the sound out by using the AVI for sound as well as video?
Thanks!
open the files in g-spot (available in tools section to the left). give us the video and audio info for each file. then we can probably help you.
I checked all 3 files with GSpot and they are all div3 video and MPEG-1 Layer 3 (MP3) audio. The only difference is that the audio bitrates are diferent if that makes any difference. GSpot also says I have the right Codecs installed which makes sense since the audio plays fine when I watch the AVI file. Any help?
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
AVI with AAC audio to AVI with MP3 audio
By Neroon in forum Video ConversionReplies: 6Last Post: 30th Jun 2010, 08:15 -
Sync problems after merging mkv video with mp3 audio
By billman1234 in forum Video ConversionReplies: 5Last Post: 29th Jun 2010, 15:00 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
AVI to H.264 with MP3 Audio
By Dylandogg in forum Video ConversionReplies: 2Last Post: 14th Jun 2007, 08:53
