I am having X2 rip speeds on my HP 200j but it used to be higher (7x-8X). I checked the DMA setting in IDE device manager and found my second drive to be DMA Enabled but currently using PIO. There is not an option to change the PIO setting because the preferred drop-down already says DMA.
Any clues on how to get both Primary and Secondary to use the DMA?
"Only Users Lose Drugs"
You may want to ask that question here:
http://forums.zdnet.com/group/zd.Windows.XP/community/oview.tpt/@thread@first@F@75@D-,D@all?ROS=1
Or here
http://www.blackviper.com/WinXP/Geronimo -
Thanks a lot A4. It was a simple answer but I would have been too hesitant to mess with my system if you didnt suggest it. Thanks again.
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 22:35
