  1. I know there are methods of fitting SVCD's on one disk but i have a stash of 900MB disks i want to use.
    However, when it asks me if i want to overburn it always comes up with invalid field in parameter and unable to burn disk at once.
    Suggestions warmly received.
    May 2001
    Have you set overburning properly in NERO?
    Can your recorder burn something that large?
  3. yes it can burn and i have done some burning that large.
    I also noticed that if i change the settings to disk at once / 96 it burns but cannot finish the burning proces although the full SVCD file is on the disk and plays but only about 90% of the time. the other 10% my player alternates between deciding if it is VCD, CD, DVD or SVCD then it bombs out. My only idea is maybe it is the bitrate it is converted at but would that affect the burning process.
