  1. highheel_hobo
    Guest
    I have encoded 5 shows with tmpge to dvd mpegs and now need to know what to use to author them and maybe join them together to burn on a dvd. (getting ready to demux). Svcd2dvdmpg is a no go, need another esay way to do it. Ive read that I should NOT join mpegs, but i need to join vobs, then burn. Any recommendations for my next step?
  2. Banned
    May 2003
    Massachusetts
    Yeah. If your MPEGs are compliant (meaning the correct size and whatnot) then any popular authoring program SHOULD do the trick for you.
    - Gurm
  3. highheel_hobo
    Guest
    LOL, yea but which ones that will let me join these together so i can put all on one dvd?
  4. Member Timoleon's Avatar
    Oct 2002
    Magellanic Clouds
    DVDLab will do the trick for you. Free trial available.
  5. Banned
    May 2003
    Massachusetts
    Any of them.
    ULead, Roxio, TMPGEnc DVD Author, etc. etc. etc.
    - Gurm
  6. highheel_hobo
    Guest
    Thanks ALL, I used tmpge author, works great! The dvd came out fine. SWEET!
