Here's my problem. I have recorded many VCD's (mpeg1) using TMPgenc. On some of the mpeg movies, I tried to shortcut and encoded audio at 192kbs and mono, instead of the standard 224/stereo (don't ask why). The VCD's play flawlessly on my APEX stand alone DVD machine. I bought a Sony progressive scan DVD player and it seems to play all the VCDs (or tracks on my VCD's) that are encoded to standards (224/stereo), but the audio skips, jerks, and is out of sync on the mpegs I encoded at 192/mono. Does anyone know of a way I can reencode the audio to 224/stereo on each of these files without affecting the video quality? Then, I can just reburn. Not a newbie, just don't know audio. Thanks a bunch.
All you gotta do is demux the audio and video with TMPGEnc for example, then re-encode the audio track in besweet or what ever then multiplex the audio and video back together
You can also try SVCD2DVDMPG.
Look here:
https://www.videohelp.com/forum/viewforum.php?f=37
Need to resample PAL audio to NTSC audio. Is it possible?
By mob in forum AudioReplies: 8Last Post: 28th Jul 2013, 22:51 -
How to resample the audio of a WMV file ?
By turbo20010 in forum AudioReplies: 22Last Post: 13th Jan 2011, 12:21 -
let the standalone do the resize (resample)?
By rebl in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jan 2010, 14:46 -
Avisynth "ssrc resample audio" help
By DaneClark in forum Video ConversionReplies: 0Last Post: 10th Jul 2009, 23:50 -
Export frame resample (PAL HDV)
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th Jul 2008, 15:07
