Hi,
How do you make a pan-scan 4:3 mpeg2? - I can't work out how to do this, and I've tried looking at ways to do this in Vegas 4 and even Canopus Procoder but I can't find the options for pan-scan 4:3.
I need to create a pan-scan menu rather than a letter box menu using a 16:9 mpeg.
Scenarist wont let me create a pan-scan menu unless I have a pan-scan 4:3 clip.
I have imported into Scenarist a pan-scan menu from a ripped DVD just to see the video properties and sure enough it indicates that it's a true 4:3 pan-scan mpeg2 video.
I'd really appreciate any help that I can get, I have been asking around in different forums and haven't had any luck.
THanks in advance,
Peter
Thanks for the link, but it's not quite what I had in mind. I should have been more clear.
What I mean by pan-scan 4:3 I don't mean panning and scanning a widescreen movie. I mean a 16:9 clip that can be viewed on 4:3 with the sides cropped.
Most of my projects are in 16:9 but I would like to design DVD menus for both 16:9 & 4:3 TVs.
Scenarist will only allow you to use 4:3 pan-scan specific format in order to use this method. It's still technically a anamorphic clip but not electronically 16:9.
I hope this makes sence.
Thanks again
Pot Player no pan scan ?
By nic3 in forum Software PlayingReplies: 0Last Post: 26th Apr 2011, 04:10 -
pan and scan vs keep aspect ratio
By tommcd64 in forum Video ConversionReplies: 1Last Post: 13th May 2009, 15:05 -
What is Pan and Scan?
By janlafata in forum Newbie / General discussionsReplies: 7Last Post: 15th Jan 2009, 22:27 -
Letterbox/Pan-Scan - Encoding or authoring option?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 02:40 -
Pan & Scan a video file for iPod?
By acid_burn in forum Video ConversionReplies: 6Last Post: 6th Jun 2007, 00:58
