  1. I'm a newbie at DVD backup...
    I have been trying to backup a copy of Sex y Lucia. I used DVDBackup 1.2 and extracted 7.8G in files, all in a single VIDEO_TS folder. When I drag it into DTOX or select the folder, the program crashes.
    I let the DVD player start the movie up before I began with DVDBackup.
    Any ideas? Thanks!
    Jun 2001
    Silver Spring, MD USA
    It's better to use DVD Backup 1.3 (http://www.versiontracker.com/dyn/moreinfo/macosx/18599), and the latest version of OS X Jaguar.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Using the Newer version of DVDBackup may help.
    Follow this guide to make sure you are doing everything properly
    http://mywebpages.comcast.net/galactica/DTOXGuide.doc
    likewise, a friend of mine had a problem with Crashing DTOX, she only solved the problem by running both Drive 10 and Disk Warrior on the HD. If you have either of those, id suggest running them since it fixed her problem!!
    best of luck
    /Galactica
