I really like its features, but when I author the created mpeg2 files from Procoder they play very fast,regular ,fast, regular. Every few seconds this happens, and the sound speeds up along with it. Now this DVD will play on my computer fine though, its the standalones that do this. Any Suggestions. TMPGnec did not do this. Im authoring with DVDlab and MF2. procoder bit rate is like 8500.
Thanks,
Dominic
Northridge,CA
I dabbled with Procoder some months ago, and as I recall- the symptoms you describe were caused by the audio track that Procoder produced as an elemental stream. I got around this by simply ripping the audio track only from the original AVI file with TMPGnec (very fast procedure- unlike A/V rendering, ripping the audio only stream takes just a few minutes for a one hour AVI) . Use the video file from Procoder and the audio track from TMPGnec for your two E.S. files and author the DVD with IfoEdit or Spruce. I know it seems like a lot of work, but I found the output quality of the video from Procoder- better then most other encoders, so the few extra minutes to rip the audio were worthwhile.
Get a pop up asking if I want to use ffdshow in Pro Coder ( what is it ? )
By beammeup in forum Video ConversionReplies: 1Last Post: 23rd Feb 2012, 03:37 -
Problem capturing with canopus mpeg pro emr...
By dhugg in forum Capturing and VCRReplies: 4Last Post: 5th Jun 2010, 15:43 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 20:29 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 20:18 -
Canopus Pro Coder Problem
By Heineken77 in forum Authoring (DVD)Replies: 10Last Post: 17th Jun 2007, 05:15
