My settings and environment: SmartRipper 2.41, DVD2AVI 1.77.3, TMPGEnc Plus 2.5, PAL (720 by 576), 16:9, Full screen (keep aspect ratio 2).
The above and the following information applies to numerous movies that I encoded with TMPGEnc, using two different PCs, and various other settings.
Problem: It appears that TMPGEnc has a consistent glitch of slightly shrinking the viewable image while filling the rest with black borders. However, it maintains 720 x 576 and the aspect ratio. The added bulk in borders is clearly seen at the sides of the movie; 10 – 16 pixels in width per side. By contrast, the left and right sides of an original DVD movie expand to the very edges of a computer monitor or TV. It’s as though TMPGEnc is pasting a 704 x 560 viewable image onto a 720 x 576 black background.
Moreover, the video sizes of some original DVDs from the store shelf don’t expand all the way to the edges of a TV or computer monitor (if I remember correctly, two PAL examples are Predator and 12 Monkeys). This irritatingly deepens the TMPGEnc problem.
I would appreciate any help on this matter.
You can use the Clip Frame option instead of the Full Screen options, that way you can cut off any black areas.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I've tried using the "Clip Frame" filter in conjunction with "Full screen (keep aspect ratio 2)" but it had no effect whatsoever.
Use the Full Screen (no margins) instead
Best Regards,
Sefy Levy,
With a widescreen, letterboxed movie, won't that truncate all my borders along with a large portion of the original video? Or do I use it in conjunction with Clip Frame to specify what to truncate and what to leave?
It should be ok with the clip frame option
Best Regards,
Sefy Levy,
I'm Glad To Hear That! Good Luck on the Next Project 8)
Best Regards,
Sefy Levy,
Video resolution (image size) calculator
By headless chicken in forum MacReplies: 10Last Post: 15th Jan 2011, 17:17 -
Consistent image shudder during payback of mkv files
By cinesimon in forum Software PlayingReplies: 13Last Post: 25th May 2010, 22:11 -
Studio 9.4.3 - Video image size too large
By rporayko in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2009, 16:58 -
Problem with Vob to DivX Coversion Image Size
By Baggins in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2008, 13:50 -
GotSent MK4 to MP4 Image Size Problem
By CameraDamager in forum Video ConversionReplies: 3Last Post: 4th Jul 2008, 09:04
