hihi^^
i have converted some clips(asf)into mpg
and burn them into vcd
i'm using easy cd creator.
but i can't play it since the 6 clips
(i have 17 small clips in it,would that be a problem??)
i can play it perfectly with the first 5 clips.
when i use the vcd machine,it plays 5 sec and jump to 00:00 again(the problem clips..)
but i even can't play them at all using my computer(also only the problem clips)
is that the problem of my cdr or my software or my burning machine(panasonic 8432x)or.......
is that better to use win on cd than easy cd creator??
or should i merge them into 1 big clip first??
TAO and DAO,which is better??
i dunno.....plz give me some suggestion.
thax a lot^^
First off any cd writer that I know of can burn VCDs I dont care what any one else has to say I have not yet saw one that cant and I have burned with at least 20 different cd writers over all. You will need to A either try encoding you movies again or get nero and drop that roxio garbadge cause I believe it is your software encoding software the 2 best are mgi video wave 4 and tmpeg so have them both and then if this all fails go buy you a super duper dvd player from best buy the best error free and the cheapest on the market ApexAD-1500 check http://www.bestbuy.com oly 99 bucks and plays mp3 cds as well so there you have it who says that I says that.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
VCD Audio converted to DVD
By Monkeyboy13 in forum Video ConversionReplies: 1Last Post: 23rd Jun 2010, 13:45 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 22:55 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
