hey,
does anyone know of any good FREE avi & mpeg splitters that i can download? thanks
There are 2 shareware programs which are faster than tmpgenc and virtualdub...
For mpgs try MPG Joiner. For avi's try Peck's Power Join -
and there may be some $1,000 programs that are faster than either, but I thought he was asking for free software....There are 2 shareware programs which are faster than tmpgenc and virtualdub...
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
MP3Nut,
Just another avenue to try. Although these are not capable of splitting at the frame level but if your intent was to just get a specific file size you could try any number of "file splitters". Try a google search and you will get many numbers of them.
These will split a file at a specific size limit right to the byte in some cases. In theory this should not create any sync issues with the split files.
In contrast, it has been noted in this forum many times about file splitting mpeg2 files with tmpgenc and the audio / video remaining in sync for the second portion of the split file.
Just another avenue, depending upon your needs.
Ed -
ED,
specifically, i am trying to break up DVD rips. i am ripping dvd's into mpegs, but with the program i use, it makes large files and does not give you the option to break the mpegs up by dvd chapter. i have dvdx copy plus too (which splits for you), but it shuts down on me all of the time and gives me errors
jeff
ps, it needs to do a good job too, i want the files to split smoothly -
mp3nut,
I understand. I was only offering up a very quick and cheap alternative if all you were after was file size. But it seems that you want to actually split the internal mpeg along picture lines (i.e., chapters).
Then, I would suggest what the others have mentioned. Each comes with its own set of problems but they all can be worked around. It depends on your frustration level and amount of free time to invest.
Ed
Two questions: Best free video converter & Best free muxing tool?
By milOtis in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 18:40 -
Good Video Splitters?
By hellfire45 in forum Video ConversionReplies: 1Last Post: 7th Feb 2011, 10:56 -
what is the best avi to mpeg-2 free converter?
By sgbd in forum Video ConversionReplies: 6Last Post: 5th Sep 2010, 09:36 -
Question about whether splitters are needed
By SimonT93 in forum Capturing and VCRReplies: 4Last Post: 25th May 2009, 19:32 -
Golf Swing & Mpeg & AVI video Streaming
By jamesh2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2008, 08:19
