Okay, this is a bit of an odd one.
I've been trying to burn a DVD using Expression and DataWrite DVD-R's (reasonably cheap media I guess).
I have made about five coasters attempting this and everytime Expression stops at the same point with an "Error writing to drive" or some other unhelpful generic error.
I contacted technical support who suggested updating the firmware (Panasonic SW-9751 Multidrive) which I did - still no help.
However, I managed to burn to a TDK DVD-RW successfully.
So I copied the DVD-RW to DVD-R (using the DVD duplicator supplied in the same suite of tools - Pinnacle InstantCD/DVD) and the DVD-R works fine and plays quite happily on my Wharfedale DVD-750S.
So I was just wondering if this might help other people who are actually authoring if they find that the DVD writer is having difficulty with cheap(ish) media.
Obviously, it takes a bit more time but you do get to try out the DVD-RW menus and things before burning the final DVD-R. (The DVD-RW doesn't play in my DVD player!).
Results 1 to 1 of 1
Need new non-AC3Filter AC3 decoder from Expression Encoder
By CasanovaFly in forum AudioReplies: 17Last Post: 30th Jun 2011, 16:41 -
Looking for some cheap Dual Layer Bluray media (BD-R DL) ..
By ahmadka in forum MediaReplies: 0Last Post: 26th Mar 2011, 22:07 -
need alternative program for microsoft expression encoder
By fixme in forum ProgrammingReplies: 0Last Post: 29th Nov 2010, 16:01 -
Problem Burning RW Media on SH202J
By builder in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th May 2008, 10:38 -
What drive(s) CAN reliably burn cheap 8x DL media?
By miamicanes in forum DVD & Blu-ray WritersReplies: 20Last Post: 16th Feb 2008, 19:09
