Worked out how to get higher ripping speeds with smartripper. Used to get 1X, now I can get anywhere between 3X-6X. All I do is to double click the NoASPI bat file before I start SmartRipper.
Results 1 to 11 of 11
Athlon 1.2,Abit KT7A,256k ram,Nvidia GF4 Ti 4200,Standard pci sound blaster,Pioneer A05 DVD burner
i have the same exact dvd drive and mobo as you, so maybe i should give this a wirl too.
you will probably like winxp pro then.. i have a athlon 1.4 with a soyo dragon mobo and a creative 12x dvdrom: in win2k i ripped at a max of 2x, in winxp pro using noaspi.bat i have seen it as high as 10.5x. no joke. took me about 10 minutes to rip a backup of titanic to vob's on my hd.
i use to get about 3-4x on win2k... and when using the noaspi.bat it pretty much stayed around 5x the whole time and had some peaks that went up to 8x.
and about xp.. just got my copy today... so ill be tryin that tonight
<font size=-1>[ This Message was edited by: DiViNeLeFT on 2001-09-25 10:25:11 ]</font> -
its in the smartripper directory... if it isnt there, download the latest version of smartripper.
listen up
if you want to rip very...very fast get a lg dvdrom 8120b fast as fu.ck, 10x all day no problems
one other thing that i noticed when testing for speeds... different dvds rip at different speeds. i guess it depends on if more or less blocks are encrypted.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
