Importing and Encoding AVI to MPEG2 with TMPGenc works fine.
But when I try to import mpeg2-files I get the message:File"xyz.mpg" can not open, or unsupported.
I try to change the priority in the VFAPI settings, but this won't help.
When I change the nvidia system settings to Hardware Acceleration->NONE, I can import the mpeg2-files, but hardware acceleration is needed.
Thanks for your help.
Environment:
MS Windows XP Prof SP1
nvidia Geforce4 TI 4200
Cyberlink PowerDVD XP 4.0
Tom, try and find the MPEG2 plugin for TMPG. I use to have a link for it but I can't find it. Do a search and see if you can dig it up.
I had the same problem, found it and put it in the TMPG folder and it worked fine after that.
Good Luck. -
Or run DVD2AVI on the MPG and save as a project file. Load the resulting d2v file in TMPG. MPGs are not listed as a file type in DVD2AVI but if you view all of the files and select an mpeg2 it will work.
Either method should prove effective.Even a broken clock is right twice a day. -
Problem solved.
Installed the TMPGenc MPEG2 plugin, change priority and works so far.
Great !!
Will test dvd2avi soon.
So, thanks to all of you. -
weirdness... I too tried to DL the mpeg2 codec for TmpEnc and I got an exentionless file which I saved to the main dir and I'm still no farther along then before... I'm gonna futz with the priority settings and go from there.
Am I off on that codec thing... yeah prolly am. heh
TMPGenc Authoring Works 4: Import custom Buttons
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 31st Aug 2016, 21:14 -
m2ts to mpeg2 HD and import to Pinnacle 14
By 129ten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th Mar 2012, 21:28 -
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
Can I import 4PM or MKV with 2 Audio Streams into TMPGEnc Authoring W 4?
By JackyWang in forum Authoring (DVD)Replies: 2Last Post: 27th May 2011, 08:56 -
DVD menu software to import into TMPGEnc Authoring Works 4
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 28th May 2010, 13:34
