i use TMPGinc most of the time and can make it do what i wont to most of the time but i try dif stuff all the time
my home DVD player will not play SVCD but will VCD and i use the hedder trick all the time but when i incode i have made a custum template for TMPGinc that works good for my setup it is
480X480, cbr950 and have gone up to 1950,i change it to fit 1cd and change the bitrate on audio sometimes...... looks as good as SVCD without tricking player
anyway cant figger out if i can make costom tepmplates for canopus??
can it be done just started playing with it today what i wont to do is change the resolution in vcd to 480x480 like in a svcd i like doing that becouse they seem to look beter on my TV 55'' 16X9 than a vcd standard formatthanks for any help
Version: Canopus ProCoder 1.01.35.0
Results 1 to 1 of 1
wish i knew when i started vcd stuff what i will know in a few years learning all the time i hope LOL
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
canopus v other devices
By marada in forum Capturing and VCRReplies: 70Last Post: 26th Dec 2009, 20:38 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Canopus DV FireCoder
By video_sync in forum Video ConversionReplies: 0Last Post: 21st Jan 2008, 03:54 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 03:56
thanks for any help
