Hi, I`m trying to convert some videoclips of the BMW films to a SVCD and they are 24fps, can I use this framerate or do I have to convert to 23.976?
Doot
You have to convert to 23.976fps. This is easily done in TMPGenc. Just set the output fps to 23.976fps and on the advanced tab click the "do not framerate conversion" filter. As for audio, technically you should slow it down as well but its so miniscule of a change you won't get any sync problems so you can pretty much just ignore it.
If making a VCD than simply do what I said above. If making a SVCD than you have to enable the 3:2 pulldown while playback option under encode mode in TMPGenc, or run your video stream through pulldown.exe after encoding to add the 3:2 pulldown flags.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
Motion Framerate
By hzgg2 in forum EditingReplies: 2Last Post: 22nd Feb 2009, 18:55 -
i need a framerate converter
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2008, 22:44 -
Divx Framerate
By DSLGuy in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2008, 11:03
