Hello: I'm thinking of buying a DVD-R. I've seen the Formac Devideon. Does anyone have it? It's a good buy? Do you know another better machine?
I want it to make my own DVDs.
Thanks in advance!!!
Do you have a G4 Tower or only a G3 mac? This will make a difference to your options. iDVD is supported on G4 macs only and you have to have a internal DVD writer. An external DVD burner is not supported by iDVD. Other than the Devideon (you must buy as a package, comes with devideon authoring software and external DVD burner) there is a program from Pixela called Capty DVD. Lacie sell it as a package with a DVD burner or just as separate software (then you can add a DVD writer of your choice)...see the link below....
http://www.lacie.com/news/news.htm?id=10026
I haven't used any other software other than iDVD so I can't comment on how well they work...But if you have a G3 then your only options are the Devideon and Capty DVD.... -
I've got an eMac, it's a G4. All I want is to burn my DVDs. I've got Toast Titanium too.
I tought the hardware is the question.
So the software for burn wouln't be a problem...
Thank you in advance
If it's OK, I'll Buy it from You...
By rodm1974 in forum Newbie / General discussionsReplies: 10Last Post: 18th Sep 2011, 11:35 -
Which TV would you buy?
By jtrinc in forum DVB / IPTVReplies: 28Last Post: 28th Nov 2010, 08:45 -
Which BD-R to buy
By jedisinclair in forum MediaReplies: 8Last Post: 24th May 2010, 00:24 -
Will You Buy A 3D TV?
By MOVIEGEEK in forum DVB / IPTVReplies: 32Last Post: 15th Apr 2010, 14:32 -
SVCD2DVD To buy or Not to buy?
By enjohn49 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st Mar 2008, 10:55
