WIll the same cq value give the same "quality" when used in different movies... and what are acceptable cq values ... between 70 and 100 seem good with vastly different file sizes (on my tests).
Sub question
Has anyone actually encoded a test of tmpgenc ultra low bitrate 240x576 resolution?? would this be better than VCD (same movie). will this res play in dvd players??
You can enter the matrix manually or just have the matrix reloaded![]()
What are you talking about?
352x576 in MPEG 2 is the CVD or Half-D1 resolution - should play on your DVD standalone.
352x576 in MPEG 1 is the KVCD standard - may or may not play on your DVD standalone.
What TMPG ultra-low bitrates are you talking about?
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
Help to batch convert Std Def MPG Letterbox 4:3 to Anamporphic 16:9
By jmone in forum EditingReplies: 0Last Post: 6th Jan 2008, 01:22 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 16:00
