I produce home movies with Pinnacle Studio, until now outputting to AVI for viewing on the PC. They've always been interlaced, and I've used VirtualDub's deinterlacing filter to removed that.
I've now got a DVD burner, and a domestic player's turning up on Friday [I hope]), so there'll be more call to watch them on tv, in PAL format.
I understand from this forum that PAL requires interlaced movies, with field order B.
I believe that TMPGEnc will [at least for 30 days] allow me to take my AVIs and turn them into interlaced MPEG2s.
Although I'd like confirmations or comments on the above, what I'm wondering is [without wanting to experiment if asking here will sort it much quicker!], what happens if you show a deinterlaced movie on a PAL tv?
Started out with valve radio, crystal microphone & reel2reel tape recorder with 'magic eye' level indication...
Most movies I buy from the UK appear to be deinterlaced and/or progressive format. I'd think the PAL tv would accept the deinterlaced video just fine from a DVD player.
And you can only make MPEG2 wth TMPGENC PLUS. Not sure if they have trial versions of it.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Thank you! [Now I have to look up info on 'progressive format'
BTW, I downloaded the freebie version of TMPGEnc, which I believe has a 30-day trial of the MPEG2 codec.Started out with valve radio, crystal microphone & reel2reel tape recorder with 'magic eye' level indication... -
All TVs (except some HDTV formats) require interlaced video (ODD FIELDS, then EVEN FIELDS). Most movies are filmed at 24fps PROGRESSIVE. PAL requires 25fps, which can be accomplished by speeding up film to 25fps, or by adding adding a frame thru a PULLDOWN process (24:1?). When you speed up the film, you also have to speed up the audio. The DVD is most likely stored in PROGRESSIVE format, at either 24 or 25 fps. It has whatever display flags that are needed to display the video properly on your TV.
If your AVIs are recorded at 25fps, then encode as INTERLACED VIDEO (because you can't deinterlace these without jerky video, because the framerate is REAL).
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 13:20 -
interlacing question
By rakan in forum Newbie / General discussionsReplies: 9Last Post: 29th Oct 2009, 08:51 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50 -
Interlacing
By koberulz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 13:32 -
HD and interlacing hell
By jchansen in forum MacReplies: 2Last Post: 4th Sep 2007, 11:14
