Hi,
What is good software that will record audio form the sound card and a bitrate chosen? Please and thank you.
I have tried some software, however, I could not figure out how to use it, or I never could get it to work.
Results 1 to 12 of 12
My first choice is Sonic XL from Cakewalk.com. It does a lot with audio but it's not easy to use.
Hi,
Thank you for telling me about the software. I am having trouble finding it. What are some other software that would work also? Please and thank you. -
Although you can't adjust the audio bitrate CamStudio is a nice program to record sound from speakers,it saves video and audio as an AVI then use TMPGEnc to save as wav,mp2 or mp3.
www.rendersoftware.com/products/camstudio
If you want to record from microphone or line-in I recommend CDex.
www.cdex.n3.net -
my mp3pro is good software for that
you can audiocentral from roxio easy creator 6
but if you don't watch what u are doing
u will mix 2 song together
instant cd/dvd 7.0 does it too but i've never took time to figured it out
as i use my mp3pro -
Thanks for all the help. The reason why I am looking for bitrate is that when I recode I want it to be good quilty.
I was not really found mp3pro software is it part of Roxi? If so then that will not work well because I have winXP and everytime I try to install Roxi it dos not work.
I have tried a program called mp3DirectCut. I was able to get it to record from window media player, however, it does not seem to work with winamp. What program should I use to record from winamp? Plese and thank you. -
Cooledit2K will do what you want. From Syntrillium.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
my mp3pro
http://www.pinnaclesys.com/ProductPage_n.asp?Product_ID=1150&Langue_ID=7
if u have instant cd/dvd 7.0
tell pinnacle
they might give it to u free
u pay the shipping -
I use Sound Forge 6, Its awesome and records from the sound card from any external device nicely. The quality sounds exactly the same as the source and lets u record it at any audio format at any birrate.
I got it to work thanks very much for all the help. I really apprecaite it. My winamp was a older once I upgraded it stated working.
what burning programs do u have
a lot of burning programs have that option
it's just usually hidden somewhere
What is a good sound card for HTPC?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 31Last Post: 20th Jan 2011, 08:59 -
A good Mic, Capture Card, and Video Editing Software.
By xSyndromex in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2010, 14:38 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 20:53 -
What software is best to use for recording TV with a PCTV Pinnacle card?
By MJBoa in forum Capturing and VCRReplies: 1Last Post: 31st Jan 2008, 19:18
